Spot Facing a hole that is not accessable. 1
jerry1423
3,428
The picture below shows a portion of a very large casting.
The holes in the top flange are drilled thru with the bottom end spot faced.
How does the machinist spot face the bottom of these holes ? Does he do it from the top with a special mill from the top ?
Jerry J.
UGV5-NX11
It's called back-spotfacing. There are cutting tools for doing this.
Thank you for that response.
Jerry J.
UGV5-NX11
Yes. Not often done, because it is slower than spot-facing from the "open" front side, but it is done regularly.
One important different requirement from normal machining is the tool: Normally, pressure from the drill or milling machine "pushes" the tool back into the drill chuck or milling machine taper adapter. More pressure means a better "grip" between the mill and the tool holder and the cutting surface into the work.
For back facing, the energy of each cutting surface on the mill is pulling the back-face mill itself "out" of the tool holder and "out" away of the mill's socket. They make adapters to resist the pulling force, you just have to pay extra to get a back-face tool that you don't use very often.
Timewise, for each back-face hole, you have to take the milling tool holder apart, put the the cutting head through the hole, re-attach the holder and tool, re-attach the tool holder into the mill, pull up everything tight, then start machining. Takes a while if you have to cut thousands of holes.
"Timewise, for each back-face hole, you have to take the milling tool holder apart, put the cutting head through the hole, re-attach the holder and tool, re-attach the tool holder into the mill, pull up everything tight, then start machining."
Look at the video I posted, no tool disassembly needed. The cutting head is moved in or out by the rotation of the spindle.
Ben Loosli
Always better and faster when the company provides you enough money to buy the right tools!
Thanks you so much for the responses. It has been a great help to understand this.
Jerry J.
UGV5-NX11
In production I would expect that part to have a single relief cut between the two ribs/gussets rather than two spot faces. In the past we've used a flycutter or upside down facemill from the top, also used a right angle head and endmill to make the cut.
If your multi-axis mill can rotate its head, then you can simply mill "upside down" by pushing up with a short facing tool.
The ones I have used, it is sent through the hole with no spot face tool on it. Then you manually put the spot face cutter on the special spindle and turn it to engage the drive pin or what ever they use. On a CNC it is an interrupted operation that requires manual intervention, that of course slows the operation down some.
CWB1 hits it pretty close. I’d use a ball end mill or radius cutter so there wouldn’t be a sharp corner. Mill between the two holes, make sure the milled area is as wide as required for the spot face diameter.
A very similar question came up in tool making class 40 years ago.
The issue I see from doing a side mill cleanout of the area between the ribs is it isn't what is specified on the drawing and would need to be an approved alternative manufacturing option. You are making the whole flange thinner between the ribs.
The backface cutter in my earlier video is the easiest method and can be done with a CNC.
Ben Loosli
Communication between the shop and the engineer is often necessary to prevent the cost of boo-boos from reaching the bottom line, wish I had a tiny cut of the millions saved annually by 5-minute phone calls. Those blind spotface tools are neat but hardly efficient. For maintenance, prototypes, or short-run work it doesn't make much of an impact, but for serial production the OP's image is a very poor design.
