juliomendez
If i have a combined system with sprinkler, hose and hydrants, i will have differents pressure requirements, for expample, 100 Psi for hydrant, 65 Psi for hose and 20 Psi as minimun for sprinkler.All the system before, will be preasurized by one pump, so i will set my pump to the highest pressure, wich is the hydrant`s pressure (100 Psi). Should i use a pressure regulator for the hoses and sprinklers and wich kind of pressure regulator should i use?
