VTAdam
- Sep 15, 2015
- 18
I am designing a 25cm (~10") two way solid slab. The dimensions of the slab are 300cm x 300cm (120" x 120"). The slab contains a square opening; 70cm x 70cm (28" x 28"). My question is what design considerations do I need to consider when designing this slab? Do I need to provide beams around the edges of the opening or is it small enough that it can be disregarded?
Thanks!
Thanks!
