  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
SS for high Salt Water ?
123Cat
67
0
0
AU
Colleague, has a SS tube 30 Dia by 400 long with an oil seal type running on the 30 dia
Slowly
Usually wet
But can turn dry
Approx 10% salt water
Looks like a galvanic type corrosion at the seal area
No heat involved
Can you recommend a metal , SS ? I dont think plastic will do it
Or maybe a sacrificial metal inside the tube ,,,, Type???
Is 316 tube best here ?
Thank you
316L will pit or stress corrosion crack in seawater. SST I typically see used for seawater would be superduplex, like 2594 or Zeron 100, or Superaustenitic, like 254SMO or AL6XN. The US Navy uses a lot of Monel and CP Titanium. They should know a thing or two about seawater.
The only other real options are superferritic stainless or CuNi (70/30).
In terms of ease to work with the superaustenitic is likely the winner, but these alloys offer a wide range of properties other than corrosion resistance so you do have options.
Any SS with a PERN >40 could be good for your applications. I recommend super duplex 2507 with equal amount of ferrite and austenite. duplex 2205 not good enough. 316 not good enough.
Thanks for the reply
Its a research setup and as you know can be complex
What he may do is just a salt water swim pool silicon carbide on viton seal if there is room
or a silicon carbide on teflon , if not,,,, its back to SS
I have lots of Al Ni Bronze here and maybe a home build tefon oil seal, on that material , will do it
Thank you
