Colleague, has a SS tube 30 Dia by 400 long with an oil seal type running on the 30 dia
Slowly
Usually wet
But can turn dry
Approx 10% salt water
Looks like a galvanic type corrosion at the seal area
No heat involved
Can you recommend a metal , SS ? I dont think plastic will do it
Or maybe a sacrificial metal inside the tube ,,,, Type???
Is 316 tube best here ?
Thank you
Slowly
Usually wet
But can turn dry
No heat involved
Thank you
