Kamran younas
- Oct 14, 2019
- 2
Hi;
i am planning to make silos in tile manufacturing plant to store raw materiel (silica sand high iron grade).
the length of solos will be 10000mm with diameter of 3200mm in SS304 materiel sheet/roll which ever is available
now the question is thickness of sheet is it sufficient to use for 3mm thickness for lower portion of silos and 2mm thickness for upper portion where as i have to keep 80 metric ton of sand in silos or should i enhance thickness and if yes then what is best thickness to use
regards
regards
