STAAD PRO UNITY CHECK 1
teddyt11
11
I am new to Staad. I have just finished building a steel platform. I am trying to check the unity ratio but when I go to the unity check in post processing under beams I just see N/A. Does anyone know how to fix this?
Thanks,
Ted
The parameters are very important and you should understand them thoroughly. With that in mind, you have to tell STAAD to check the members using a design code. To do this go to the "Design" tab. On the right of the screen is a button that says "Commands...". Click this. Now choose "CHECK CODE" in the dialog box and assign this to the members you want checked, presumably all of them.
May be you forget to assign the properties.
Sometimes you assigned but it can be like that.
So select the properties and assign th material agian.
It can be OK.
If no properties or materials are assigned, STAAD wouldn't even run an analysis.
