Often times stainless bolts and nuts have a lowere rating, since high strength bolts are usually Q&T alloy steel. To produce similar strength levels in a SS bolt A martensitic alloy such as 410 must be used. Even then the corrosion resistance is not incredible. If this is for initial design you may have to go to a larger diameter fastener. If its a swap out to gain corrosion resistance you my not be able to get exactly what you want.
(For further note, I've under taken a project to replace all of the carbon steel fasteners underneath my car with 18-8 or A2-70 fasteners, this is an annoying project since the A2-70 M10 coarse fasteners I'm using have a different wrench size than what I'm replacing, I have to keep swaping wrenches.)
Nick
I love materials science!
