@GTAW
quote"I take issue with preheating aluminum."
you are the pro, I now know careful care must be taking of heating any type of material as not to effect material properties.
no worries it was 40-50 years ago, all I know and I saw the results of preventing cracking, aluminum is tough to weld with stringent NDT requirements.
I forgot now what the specification requirement was back then but it was allowed then , it may have changed now, requirements do change. very small indications that were subsurface and surface.
surface indication were easy to rework light grind with flapper wheels, subsurface had to be drilled out and rewelded. PITA in finding the exact location with X-ray films.
if back then if the internal procedure were not followed, radio graphic and flow pen indications doubled, fixing cracked welds was not easy.
and try to salvage parts was not 100% effective. prevention was the key.
I believe the temps were so low it did not effect the tensile requirement, but I don't remember so I bend to your professional knowledge. you are more current.
quote" I try to minimize the interpass temperature by cooling the material to room temperature using a fan or even wet rags when making multiple pass welds. It reduces the probability of overaging or reducing the strain hardening strength in the HAZ. "
Quote "If the welds appear "cold", it is an indication the welder needs to use more current. Perhaps a larger tungsten with higher current carrying capacity is needed."
important information I forgot, thank you so I will take note
"Sorry to digress from the original question."
same here, but I like this type of discussions there is a lot I forgot, that I know just touched the surface.
