Startup drawing
BarryCole
Aerospace
Oct 6, 2015
32
With Draftsight, when I open the program, and it comes up with the Noname drawing, which DWT file does it use as a default, and how do I change it.
Also, at the bottom of the screen, there are two numbers that show the position of the cursor. These default to showing the position from 0,0
How do I change these to show the angle and distance from the last point selected.
As ever, thanks for your help.
BC
If you right click on the tabs, you can choose your templates or go to the Print Config Manager.
Right click on the task bar near the 0,0 and you can choose Absolute or Relative.
I don't use DraftSight often enough to provide details, but I think this will get you started.
Sylvia
BC, after you create your default template go to tools, options, system options, open, saveas, template file name for smartnew for the location of the default template you will use.
Diego
Diego, Many thanks, that has sorted it.
Can you help with this, Sylvia's idea did not work
What I want it to show is the angle and distance from the last point I picked. I think I have been able to get this in the past, but I could be thinking back to my AutoCad days.
I thought it was a command called Coords, but that does not seem to work.
Any ideas please.
BC the command is setcrddsp. Change the default from 1 to 2. You may also at times want to change the location of the coordinate system, this command is ucs, with options listed.
regards, Diego
