Static Load Testing of Wood Structures 1
enigma2
38
Is anyone familiar with a method for static load testing on a wood structure? I know this is usually only a typical method for concrete structures since wood and steel members can be field measured and analyzed, but the structure I am considering has some deterioration and the owner has expressed interest in a full-scale investigation.
I have checked ASTM, but have had limited luck. Any leads would be appreciated.
IBC Chapter 17 - specifically 1713 has in-situ load tests.
These three obscure documents may help give you some ideas:
"Testing of a Full-Scale House Under Simulated Snowloads & Windloads"
"Nondestructive Assessment of Single-Span Timber Bridges Using a Vibration Based Method"
and a follow-up
[idea]
That's an AMAZING paper. A printout goes in my library next to ASCE 7.
