Hi all,
I want to model something that is not completely straightforward to me.
First I've conducted a frequency analysis of my part. Next, I perform a Steady State Dynamic, Modal analysis to construct FRF's of my system. I want to be able to specify the displacement at the first resonant frequency. The harmonic input force should thus be modified accordingly. If I understand correctly I can only apply a harmonic force in this step. The amplitude of this force is unknown beforehand.
Does anyone have experience using this type of analysis and do you have any tips on how to solve my problem?
If you're interested in my goal:
I'm modelling a composite plate with a crack. I can modify the crack length in my part and run the simulation multiple times. The crack length will influence the stiffness of the system and thus its modal characteristics. The FRF components will shift. By setting the displacements at the first resonance constant, the stresses and strains will be of the same order of magnitude for that specific frequency.
Thijs
Thijs
