I have a somewhat typical steel beam to steel beam moment connection (see attached). The cantilevered end of the moment connected beam is 16 feet. Strength does not control as I am only at about 40% capacity. However, I very much care about limiting deflection of the cantilevered end. My question is: Do I design the moment connection for the full bending capacity of the beam or do I design it for the actual moment on the beam? Surely, a moment connection with 2 rows of 3 bolts will rotate more than one with 2 rows of 12 bolts as I have shown, right? AISC 13th ed. Commentary on Specification Section B3.6 (pg. 16.1-218) appears to maybe address this but I am struggling to understand it.
