I am analyzing an existing platform in a mill. The grid of the platform is 16'x12' and it is supported by W8X18 steel beam between columns. There are two W8X13 intermediate beams placed 4'-0" o.c. There is a 3/8" THK. diamond pattern steel floor plate spanning 4'-0" o.c.
The client wants to use the platform to support lift truck which distributes 300psf total load on the platform. I need to check if the existing diamond plate is adequate or not. I also need to check existing framing supporting the platform.
Is there a way to check the adequacy of steel diamond plate? Need some advise.
Thank you.
Thank you.
