I work mainly in the structural steel world so the steel analysis of the attached sketches is not a problem, when it comes to the interaction with the wood is where I get a bit confused.
I believe my main concern with this connection would be the bolts ripping/tearing out of the wood, (as long as all the steel strengths are adequate to carry the load), but I'm not sure how to find out how much load can be put on the bolts before the wood fails.
I've attached two .pdf files, (tried to at least) to further detail the situation I have. Any input will be appreciated.
Thank You.
Thank You.
