SteelPE
- Mar 9, 2006
- 2,759
I am trying to figure out the stiffness of a base plate for a steel column resting on a perimeter foundations wall. I am running through the procedure in the PCI Design Hand Book (section 3.8.2). Using the PCI I can easily calculate the flexibility of the base plate and the anchor bolts but I’m not sure how to account for the flexibility of the foundation wall/footing.
The PCI does give an equation for the flexibility of the foundation but that is for an isolated footing only.
