Zibraz
- Feb 23, 2021
- 27
I'm struggling here. I have a clamp which will be tightened over a rod. The clamp and rod will be enclosed in a box and the thru hole you can see in the model will not be easily accessible. I'm trying to think of ways to fit a captive screw in this thru hole so it can be tightened from outside the box. I'm trying to look up information on typical captive screws, but all the information I find only references sheet metal. Can captive screws be fitted to machined blocks?
Failing that, what other methods can I use to have a screw in this through hole without it falling out? I want it idiot proof so someone won't fully loosen it. One idea is a seperate sheet metal plate fixing onto this area with it's own captive panel screw, but that seems inelegant.
