I am pursuing a new type of project, but am having trouble finding the right references and guidance. The IBC reportedly requires that storage racks over 8 feet in height be designed and structural calculations provided by a PE. I can not find this requirement in the IBC. Can anyone point me to it. We are operating under the 2003 IBC, but will soon be moving to the 2006 IBC.
Realizing that the components of high-piled rack storage systems are proprietary, how is an independent PE expected to verify capacities for an existing system that was previously installed? Is this just through the use of the manufacturers load tables? How do you calculate overall structural stability then?
I understand that this is a general question, but I just need some help finding the right references. Thanks!
