Jacob Cheverie
Aerospace
- May 14, 2019
- 77
I have attached a very basic image of a part that I am dealing with. Datum feature C is a cylinder, datum feature D is a cylinder, and datum feature E is a cylinder. These three cylinders are mutually orthogonal.
(1) Datum feature D has a Straightness tolerance at MMC.
(2) Datum feature C has a Position tolerance at MMC with respect to datum feature D at MMB.
(3) Datum feature E has a Position tolerance at MMC with respect to primary datum feature C at MMB and secondary datum feature D at MMB.
I am trying to establish the boundary size of D at MMB for the third geometric tolerance as listed above and I am running into an issue. The boundary size of datum feature D would be its MMC size plus any applicable geometric tolerances to higher precedence datums (per Y14.5-2009 4.11.6/2018 7.11.6). In this case, the designer does not include a geometric tolerance on datum feature D with respect to datum feature C. They actually have it the other way as is mentioned in case (2).
My question is as follows: To determine the MMB size of datum feature D, am I allowed to use the Straightness tolerance to increase the boundary size even though the Straightness tolerance is not defined to be in effect while constrained to datum feature C at MMB? Would I be violating datum feature precedence by adding this tolerance to the boundary size?
Thank you.
Thank you.
