strainer
Sherifhosny
Industrial
Jan 13, 2020
15
I was asked to make the technical specification for the strainers we have in the PID in order to send it to the suppliers asking for quotations.
What are the information I should put in this technical specification?
Strainer type, strainer mesh/perforation size, fluid service, body material, end connections, design temperature/pressure, flow rate are typical
Does it need PI/dPT ports? Dimensional constraints? Solids content?
There's a lot of things you COULD put in the specification. I'd recommend you ask a senior process engineer or at a minimum check out some generic specs from manufacturers to get an idea of what options/features are available.
Also do you want quick open closures ( to ASME VIII normally) or bolted closures.
Also max differential pressure you want clean to dirty ( usually 0.1 to 1 bar)
Drain points and valves or not
Vent point or valves
When submitting a PID you are supposedly at the very end of a designing process, where all technical decisions have been made down to the smallest details.
If the project (as very often seen at PID description stage) has not reached this level, or descriptions are not made by engineers qualified as specialists you have two options: get hold of a specialist to make the decisions, or open up verbally by describing verbally exact the effect and targets you want for the process, operation, maintenance and lifetime of the product.
You have already by others got good advice on necessary details, when correct type of filter form and mesh details/types have been selected.
