Strand7 Reaction Forces
gharli
42
Hi All,
I very well may be missing something, but I cannot find out how to show nodal reactions in Strand7? I've tried the following routes:
1. Opening the results viewer and selecting the "node tab" - the only tab at the bottom of the window is for "displacement". I don't see "reaction" anywhere.
2. Element results window - again no option for reaction anywhere! Only options are "displacement" "stress" "force" and "moment"
3. Using the peek option - alas, under nodes there is nowhere that shows reactions, the only peeking i'm able to do is to obtain displacements and rotations.
4. Graphing tool - also not working, the only option to graph under nodes are displacements.
Am I missing something? Attached is screen grab of some of the options above showing "reactions" missing.
Plate element stresses and forces are showing perfectly.
Please help! Using strand7 V2.3.8.
Thanks,
_________________
Jones & Wagener
Great! Thank you very much Doug.
For reference if others stumble on this simple problem, tick box location is here:
_________________
Jones & Wagener
Looks like you are using an earlier version there.
In the latest version the "calculate" options are on a separate Results tab, in the solver dialog box.
Doug Jenkins
Interactive Design Services
