Strange New Physics! Water boils slower in the US
IRstuff
Aerospace
We typically travel with a portable water heater for boiling water to make tea while traveling, because when the hotels have coffee makers, they're typically so imbued with coffee taste that even several pots of clear water still result in a strong coffee smell.
Interestingly, in the last 4 countries we visited, water boils approximately 4 times faster there than at home.
It's the electrical power, of course; all 4 countries we visited use 220VAC, so double the voltage, hence quadruple the power, so approximately 4 times faster boiling.
TTFN (ta ta for now)
What is the total KWH for both voltages? Are they the same?
It'd be close. 1/4 the power taking around 4X as long to boil. I'd guess that the lower wattage would use more kWh because more time to get to the final temperature gives heat more time to escape.
The supply cord may be badly overheated.
Ohm's law
Not just a good idea;
It's the LAW!
Is there any long term power savings for a country to use 220V vs 110V? or saving for equipment or wiring costs? Is the higher voltage more costly? or costly just because 220V equipment is less common?
Hypothetically, yes; the resistive losses in the distribution network should be noticeably reduced. However, in the US, that would require a massive refitting of a huge amount of electronics to run off 220V
But much new electronic consumer equipment is powered by switching power supplies that will accept any standard voltage, world wide.
Ohm's law
It's the LAW!
Thanks, IRS, and waross...
