Hello all,
I want to make some design changes to a bracket attached to an IC engine and I want to make sure I end up with a part as robust as the one it is replacing. Tooling is expensive so I would like to validate the bracket using FEA techniques before actually ordering parts. I have vibration data from the old design but I'm not sure how to put it to good use. Should I just concentrate on making sure the stiffness/ resonance is comparable
between the two designs or am I missing a better approach?
Thanks!
Mel
Thanks!
Mel
