Strength Wizard
rossly
Automotive
Sep 22, 2003
115
Has any used this, if so what are some opions.
I am looking into using this as an upfront feas. option. Our designs would still need our CAE depts. signoff but from a early stage is it easy enough to use and are the results on par with a full blown analysis?
Thanks.
I have used it as an early design verification tool and it works good. I can say that for simple geometries the result is good but for more complex ones it ain´t as good as a full blown analysis but it gives you at least a hint what needs to be done.
A tip: When you constrain the modell you usually use an edge or a surface, but with the "subdivided face" feature you can split the surface to an userdefinied size and shape to replicate the load case more realisticly.
I've used it too, and it works well. But only for preliminarey FEA - go/no-go situations. The FEA dept will still need to do final optimization.
-Derek
DL Engineering Services
specializing in CAD Design Consultation Services
