This is the new problem I am working on, on one of the mounting bolts. This time I will try my level best to give you guys as much of info as possible with pictures. This is our major issue (Customer satisfaction)
Problem where find: In the field, somewhere between 5hr to 440hr of engine run in water (no problem in assembly). Problem is seen only on high horsepower engines.
Joint Description: the whole engine will be supported by a structure, the engine is mounted on to the structure with 2 upper mount bolts and 4 lower mount bolts. So in service the whole load is carried by those 6 bolts and the problem is with the 2 upper mount bolts which are breaking underhead. Warranty issue. Some of them breaking at underhead of bolt and some of them come loose.
Fasteners used: ½-13 UNRC-2A,17.4 strength bolt (grade 8 high strength stainless steel) cadmium coated, fastener driven into blind hole (no nut), split lock washer under head and loctite 272 on the threads.
Depending on the heat treatement of the bolt, the proof load of the bolt can vary from 14,687lbs min to 17500lbs max. our supplier can get a mixed fasteners so we really want to keep the 14,687lbfs as proof load for margin of safety.But our tensile lab did some tests on 4 production bolts and they found the proofload to be 18000lbs.
Clampload we are shooting to: 9000 lbs average on each bolt.
Service loads on the joint : don’t know, design engineer dosent know either,but he said he gonna try to get the number.
Engineering dept thought: our eng dept thinks that , the failure/fracture of bolt head is due to hydrogen embrittlement or stress corrosion failure. But we see some of the bolts failed in 5 hrs of the engine run, so how can it be a corrosion failure if u have the engine in water for just 5 hrs? some of them failed in 440 hr (this I can agree it may be of corrosion failure)
What my guess is 9000 lbs of clamp load is like 50-60% of the bolt proof load. I think the bolts are failing because of the low clampload as cyclic loading/vibrations.services loads acting on the joint.
What do u guys think?
