PSUengineer1
- Jun 6, 2012
- 151
Group,
I am interested in learning more about structural clay tile basement wall failures. From my humble experience level with this material I observe that the walls fail typically as a result of lack of reinforcement in the horizontal cells and inadequate wall design. In addition, the walls many times fail as a result of horizontal earth pressure and hydrostatic pressure from water (i.e. additional pressure from saturated soil).
As I understand it, the walls must be supported at their base (generally by footing or concrete slab) and at the top by the floor structure.
The distribution of the total lateral load between the vertical and horizontal span of the wall depends on the height and length of the wall, and its stiffness in the spans. The lateral load on a basement wall will be carried entirely in the vertical span when the length of the wall between supports approaches three and a half to four times the height, according to the Handbook of Construction Contracting (Vol 1 Plans, Specs, Building by Jack P. Jones).
Questions:
1. Wall stiffness in the vertical span can be increased by embedding vertical steel reinforcing but how in the world do you reinforce structural clay tile vertically?!?!?!?
2. Has anyone out there observed structural clay tile basement wall failure in the horizontal span (vertical crack)? I typically see structural clay tile basement wall failure on the long walls (vertical span, horizontal cracks).
3. As far as lateral load distribution to the basement walls go, am I on track by using the 3.5-4.0 X height rule of thumb that I stated in paragraph above?
4. Does anyone have a copy of the Handbook of Construction Contracting (Vol 1 by Jack P. Jones)? Is so, would you recommend purchasing it and using it for reference in doing "down and dirty" preliminary engineering calculations?
5. Any reference material that another engineer can provide me with for the purposes of educating myself more on this topic would be highly appreciated.
Thank you.
Questions:
Thank you.
