abdallah hamdan
- Oct 13, 2021
- 36
As stated in section 12.7.1 in ASCE 7-16, "Foundation Modeling. For purposes of determining
seismic loads, it is permitted to consider the structure to be
fixed at the base. Alternatively, where foundation flexibility is
considered, it shall be in accordance with Section 12.13.3 or
Chapter 19."
I'm training to design a 13 story building Using Etabs 2019, based on the Statement, Should I always model the base joints as a fixed joint to design the building and should I design the Footing (isolated or mat), to have fixed support with moment reactions?seismic loads, it is permitted to consider the structure to be
Chapter 19."
if this isn't always the case, what are the cases that I could model the base joint as pin support?
