StructuralAddict
- Jul 19, 2016
- 106
In ACI 318-14, the commentary to Section 11.3.1.1 states the following:
"The minimum thickness requirements need not be applied to bearing walls and exterior basement and foundation walls designed by 11.5.2 or analyzed by 11.8."
So, does this mean that the minimum wall thickness requirement is only applicable when the "Simplified Method" of Section 11.5.3 is used?
Thanks.
Thanks.
