XR250
- Jan 30, 2013
- 5,925
I am building a house. In one area, I have 2x6 studs @ 16" O.C., 5'-6" tall. The plumber needed to drill a 4 1/2" hole thru the dead center of 3 studs (the hole is centered top to bottom). I figured I would reinforce them with angle iron later. However, when I run the numbers on the stud as is (1/2" material left on each side of the hole), I end up with a combined gravity and wind load stress of under 700 psi for the remaining portion of the stud. They are #2 SPF studs. Should I even worry about reinforcing them?
