Substructuring of 3D models in ANSYS 1
Patyuchenko
17
DE
In order to perform steady state thermal analysis of a large model of a chip I am using substructuring (bottom - up) technique in ANSYS.
But I encountered the following problem:
for substructuring I should have the interface nodes of the superelements (master DOF) at the location of the interface nodes of the adjacent structure (or another adjacent superelement) (within a certain tolerance). It is not a problem in 2D modeling where the interface between the adjacent structures is usualy represented by lines and I can easily assign a desired number of elements per common lines. However I am performing a 3D simulation where not only the lines are the interfaces between the adjacent structures but the areas as well.
I would like to know how can I obtain the same "pattern" of a mesh for interface areas which belong to two adjacent superelements which in their turn are meshed separately from each other (bottom - up substructuring) thus fulfilling the prerequisite of the interface nodes coincidence for the substructuring technique.
May be somebody had the same problem and solved it? I would be very grateful to you for any help.
Thank you very much.
Best regards
if, the interface areas are identical, you can obtain identical meshes for the them.
First step:
Mesh areas with plane or shell elements of type MESH200 (keyoption as needed)
Second step:
Mesh Volumes as usual
Third step (optional)
Delete MESH200 elements.
Alex
Thank you very much Alex for the helpful answer.
Do you know, is it possible to view the nodal solution of the whole structure at once when all the steps of substructuring are finished?
I can see the solution (influenced by the model) for each single superelement separately after the Expansion Pass and the solution for the model also separately (influnced by the superelements) but not everything at once.
Thank you very much in advance.
Best regards
Anton
Sorry, I can't help you with that. I have never used substructuring...
Good luck!
