BTJCM
- Oct 3, 2018
- 23
Hi all, I make a lot of test with different type of coagulants, and the conclusion from all the experiments is that the coagulant(aluminum oxychloride) which we are using right now doesn't remove very well SO4 from the waste water, when we are using a little bit more than usual(which happen 1-3 days in week) hydrosulfide. The other coagulant which I tested CFS(coagulant-flocculant-sorbent(PACL)) who have 10-11% Al2O3 or 20-23% w/w PACL, SG = 1.18 50% basicity and 10,5% w/w Cl pH = 6.8-7.2, remove better SO4, but is not so efficient removal for COD, BOD5 and sulphides. So my question is: can I mix them and acquire better results, or I need to search for other solution. I can increase a little bit the quantity of coagulant dosing from 0.5kg coagulant/m3 waste water to 0.6-0.65 kg/m3, that will slightly improve my situation but wont solve it. Aluminum oxychloride have 10-13% AL2О3, or 10-13% w/w, SG = 1.13 pH = 4-5. The pH of waste water before treatment is between 7.5-13.5. The flow rate of waste water is 63 l/min.
Thank you in advance.
Best Regards,
George
Best Regards,
George
