Mrinet
Materials
- Jun 2, 2008
- 11
Is Super duplex (S32760) girth welds be tested at -71 degrees C. The base material was tested at -71 degrees C (as per DNV OS F101) where the MDT is -51 degrees C. This is a line pipe.
I know with Solution annealing (base material) can be successfully tested at -71 degrees C. Can this be achievable for welds, which will not be solution annealed. Any thoughts?
