Super Yacht sank in the med 3
This appears to be the location of the engine room ventilation. That would certainly let water in at 88 degrees. Perhaps there is a procedure to seal those hatches when rigged for sailing. Was the vessel sailing or motoring during the storm? If motoring, these hatches would have been open.
If hit by a wave from the beam that cause them to lay over, well there is certainly a lot of glass on the side of the house.
Ships and boats tend to drift broadside to the wind. That AIS track shows otherwise. I don't know if this applies differently to keeled boats.
From what little I have seen, cargo ships have a fairly uniform side profile both above and below water; the have all the shaping of a rounded brick.
Sailing ships, which I once had considerable interest in, tend not to. In particular, the mast of the Bayesian alone represents a considerable surface for wind to apply a load forward of the middle. It also looks to keep the foresail wound around its rigging, adding more area for the wind to act on. If all other loads are balanced, those alone will turn it downwind.
There are also two forward doors for small watercraft to be aboard and some witnesses thought it went down by the bow; this is in keeping with an early speculation that an access door had been left open.
It looks like there are already efforts to muddy the water:
But Mr Costantino, CEO of Italian Sea Group - which owns the company that built the ship - insisted it took 16 minutes from the moment the boat was caught by the wind and began dragging its anchor before it finally sank, which should have given the crew enough time to warn passengers.
Dragging the anchor doesn't normally cause a ship to sink, so the 16 minute reference makes no sense. It makes sense to know how long it was from the time it began taking on water until it sank.
I can imagine that it was mainly OK dragging the anchor by the bow, but at some point the anchor line was lost, allowing the drag on the mast and forward rigging to turn the ship sideways and heel. If a forward garage door was open that would allow the door to go under, flooding the forward portion and maybe the rest of the yacht; few details on interlocks and watertight doors.
I would be surprised if it was a knockdown with no sails up, even with the keel up. That is still a more than literal ton of weight.
euronews says:
A source briefed on the investigation, however, told Corriere della Sera that divers who went down to inspect the wreck found the mast in one piece, with the boat intact — its hull unbreached, its hatches closed, its windows in place.
However, it is laying on its right side, so the starboard garage door may be open and the divers cannot see it.
Interesting comment:
There is only one reason why a boat sinks. It gets water in the people tank.
Another superyacht recently sank at anchor from leaving the garage door open in somewhat mild seas so it's not an unheard of cause.
Was the yacht possibly taking on water even before it lost the anchor?
Ohm's law
Not just a good idea;
It's the LAW!
The alarmism I was alluding to is that a 90 deg knockdown is perfectly survivable, to the extent we carried on racing afterwards, and probably won.
Cheers
Greg Locock
What was the beam of your vessel that got knocked down? Was anyone sleeping inside? Did your boat have an engine room with ventilation?
Not the point. The point is 90 degrees is survivable if you design for it. Did the DFMEA include knockdown as a criterion?
Cheers
Greg Locock
360 degrees is survivable for some sailing craft. Probably not one as large as this one.
...and with the engine room ventilation, it could take on water.
There's now mention of a down draft hitting the vessel. Also could the fact that it was anchored affect how the boat reacted?
So a big downdraft and the anchor chain pushing in kiddie directions pulled the bow down?
It is possible the forces from the anchor could have breached the hull. The anchor transfers forces to the hull through a winch. It's possible the foundation failed and caused a breach. The anchor is also attached to the hull via weak link. Maybe the weak link wasn't weak enough and that damaged the hull.
I don't see any probability on a downdraft strong enough to push the bow down and sustained enough to hold the bow down.
A sudden change in wind direction could cause the boat to make contact with the anchor chain.
A boat doesn't float in aerated water. There was a aemi-submersible oil rig that capsized some time back because the well had a blowout and the gas aerates the water enough that it lost buyancy.
The depth of the aeration would need to exceed the freeboard (caveats about waves and heeling) to get them to sink. The little ones that I have seen in the news are because someone cranked up the anti-ice aeration too high, so the water density was lowered all the way to the aerator depth. I think people have drowned this way from falling into water treatment aeration tanks.
I would not expect sufficient churning of the water to do the same to a yacht from a water spout; perhaps a deluge of water directly onto it? Even that requires open hatches.
Google isn't aiding in finding a boat sinking at the dock from aeration, but this is one amusing thing I found about dealing with an upset condition. Who would have guess that bolting ladders with the rungs vertical on the sides of the cabin would have been smart? Sure people make fun of it, but it pays to be prepared.
There are a bunch of Navy ordnance videos where a explosion amidship lowers the density of the water enough that the hull, damaged by the blast in the uplift portion, if finished off when the remaining buoyancy is at the bow and stern and folds it like a church luncheon chair because the middle isn't being supported by the new foamy water installation.
The irony is that boats and ships tend to be much more stable when upside-down than they are right side up.
