thread116-226362
In the original thread referenced above, it was suggested that there were a few alternatives for surface finishing to remove machining and handling marks: I was hoping someone could help me with the following:
If you use a vibratory tumbling with plastic media, I would have thought the pieces would create new marks as the pieces hit each other in the tumbler? Do you just severely limit the pieces you put in the tumbler, or do you not find this to be a problem?
If you were going to do it via sanding on a lathe, would you recommend say a 160 grit and then jumping to a 320 grit, or would that still be too coarse and show up in the final part?
Has anyone had a problem with pitting showing up after the etch and clear anodize, or are these likely handling marks being confused as pitting?
If you are trying to achieve a mirror finish and you buff the pieces with a cotton or sisal wheel and polishing compound, does the subsequent frosted finish still have a mirror like appearance? In this case, would you skip the etch?
To avoid having to surface finish to remove machining marks, has anyone used a double etch successfully? I can't imagine the etch taking enough material off to remove these. Are there any chemical alternatives?
Thank You in Advance for Any Opinions!
