Surface Roughness Ra 3.2um 3
Acester
Industrial
Sep 15, 2010
5
What is the tolerance for a Surface Roughness Ra 3.2um. Is it 3.2 ± the general tolerance on the print. Or is 3.2 the max reading as in 0 - 3.2
Roughness is usually given as an RMS statistical average number.
I think a resource like Machineries may have enough info to help you out.
Other wise looke in ASME B46.1 or equivalent.
Surface roughness is a maximum, meaning Ra 3.2 micrometers maximum.
Which is why ASME B46.1 allows you to specify an upper and lower limit.
Normally though, only the upper limit is specified.
My readings range from .97 - 1.02. is this "too smooth" from the 3.2 callout
Unless they explicitly list a lower limit I don't think there is such a thing as 'too smooth'.
There is no lower limit callout. Thank you KENAT
