Surface sinks in small polyurethane (TPU) washer 3
Hawker1
Industrial
Nov 25, 2005
First time user of a C60A10W polyurathane. Parts are
three sizes .38, .25 & .18 dia. x .05 thick. Surface
must flate an free of sinks. These are vacum seals.
Processor has try a range of injection speeds & pressures
and temps suggested by supplier.
Is it dry prior to moulding?
Tool venting?
Too much shear heat being put into material (e.g too high back pressure/too high screw surface speed?)
Rgds
Harry
If it sinks, pack it in harder by using:
More injection pressure
More hold up pressure
More hold up time
larger gates, runners, sprues etc
Is the ring check valve sealing
Is there enough injection stroke to reliably close the ring check
The usual problem is too small gates. Urethane takes gates at least 1/2 the thickness of the thickest part of the molded part. Fill moderately fast and keep the hold pressure at 50% of the peak injection pressure. Make sure your cushion is holding. You may have a leak in the check ring valve. Cut the part in half and you will likely find some shrink voids.
