lumenharold
I have been having problems with assembly files that open fine sometimes and other times open in a low resolution or cause SW to crash. None of the problems are consistant from file to file nor do they always appear in the same files. I can open an assembly that looks low rez and then open a sub-assembly and it will look great. I tried to set the resolution for "all parts" with the assembly in the tools settings and my OpenGL check box is now checked and grayed out.
I have a Dell 690 with a Quadro FX 4600. The SW site lists the approved driver for the Dell as ...9777 but for the same card under nVidia as ...9778. I have 9777 installed as a suggestion from my VAR.
Any suggestions would be appreciated. The crashing and slow rotation speed with the SpacePilot is a drag. Thanks.
Harold
SW2008 SP1.0 OPW2008 SP0.0
Harold
