Sweep Along Guide and Variational Sweep 2
TufailShams
4
I'm trying to connect 2 similar sketches but top one is scaled down. I tried variational sweep but and sweep along guide but both show the error. Attached image for further clarification.
First off, I would strongly recommend you expand your dialogs so that you see all options in them (3 triangles above the OK Apply & Cancel buttons). Next, I would use other commands that would be more appropriate given how you've set up your Sketches. Try either Through Curves (change Alignment to By Points or other choice to control twisting) or try Swept.
Tim Flater
NX Designer
NX 11.0.2.7 MP11 Rev. A
GM TcE v11.2.3.1
GM GPDL v11-A.3.5.1
Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
You must use the ADD NEWS SET button between selecting each set of curves.
Read the bottom of your screen carefully as it will guide you quite well.
I would also suggest that you use more than 1 guide curve to give you more predictable results.
See the attached file...
"It is impossible to make anything foolproof because fools are so ingenious."
