blaker
- May 30, 2007
- 2
thread279-155022
The above thread provides a good preface to my following comments:
Our arc hazard analysis is complete and we have the labels affixed to the equipment indicating the Hazard Risk Category and appropriate PPE etc. Realizing that NFPA-70A (soon to be a CSA document)and IEEE-1584 are not perfect documents and deal more with the radiant heat from an arcing fault and not the arc blast components, I am attempting to push the idea to the field maintenance personnel that the PPE dictated by the HRC on the label should be worn weather the door is open or closed for tasks performed on gear without arc resistant doors. I have heard numerous comments at conferences reminding us that non arc resistant doors are not designed to withstand an internal arc blast and could greatly contribute to the effects of the flash/blast. This idea is especially being contested when opening/closing 480V branch circuit breakers, using the outside handle with door closed. I'd appreciate your thoughts and comments on this.
