rockman7892
- Apr 7, 2008
- 1,168
I'm looking at a project where the customer is requesting a new MV Switchgear lineup that will have two mains fed from two alternative upstream sources. These two mains will feed onto a common bus and will be interlocked so that only one can be operational at a time.
I'm used to seeing lineups that have a tie between the two mains in order to isolate the one side of the gear if needed. In absence of the tie breaker you still have backup/redundant sources through the two mains but you need to take down the entire lineup if there is maintenance or an issue that requires de-energization of the bus.
I'm curious if anyone had typically seen this arrangement and what some of the pros/cons are?
