Daparojo252
- Mar 25, 2015
- 11
I am need of preventing a M42/M45./M48 Nut from coming loose during operation whilst underwater on a pumping application. It will be exposed to seawater and vibration, so has to be resitive to saltwater corrosion. 316,304 and 303 Stainless Steels can be problematic under those conditions due to pitting etc. I am currently leaning towards Monel 400.
A Tab Washer is the preffered method of preventing the Nut from turning. Tab Washers at that size are only available in Steel and still hard to come by, especially in the materials we would require so we may have to look at getting some manufactured to our design. Quantities are not great i.e. less than 1000.
I would be looking at a material that in sheet form the thickness of the washer would be less than 2mm with a 16mm long tab to bend. Would Monel 400 easily bend and keep shape? Or is there a more suitable material or solution?
Many thanks
Many thanks
