Table Curve
ianstifle
Marine/Ocean
Jun 30, 2004
14
I've created a group of 38 table curves in an attempt to easily create a lofted protrusion of a ship's hull. the curves are all parallel to each other. However, when I go to the lofted protrusion command it will not accept the input from a table curve. any suggestions on how to do this without tracing each curve into a sketch??
You may want to use the 'Curve by Table' command to create the curves. You can use these curves as cross sections for BlueSurf or Lofted Surface commands. After creating the surface, use 'Thicken' command to create a solid.
HTH.
