Tank per API 650 3
MhFitri
13
Hi guys,
I wish to create an analysis for a blending tank as per API 650. The tank having a cylindrical section of 1800mm H and I.D with a conical section at bottom from 1800mm to 60.3mm nozzle opening. However, after going trough the API 650 12 Ed, the standard does not give detail explanation regarding conical section. ASME however does, and the calculation is there when i`m using PV Elite, but the client insist of using API 650 as the standard because the tank is designed for atmospheric use. Please advise.
Any opinion and ideas would be mostly welcomed
API-650 is set up for flat-bottom tanks.
You can design per ASME even if a code stamp is not required.
You can design per API-650 to the extent applicable, but it won't provide guidance for odd geometry.
API-620 includes provisions for compression rings that may be of help.
You need to tell the client you are not designing a tank, you're designing a mixing VESSEL.
As J Stephens points out, You can easily design to ASME VIII or similar pressure vessel codes with zero barg as your design pressure. Pressure at the bottom will be the pressure from your materials.
Quote them this from API 650 section 1.1 scope "This standard applies only to tanks whose entire bottom is uniformly supported..."
This means flat on the ground.
Please don't use the abbreviation "ASME" to mean ASME VIII. Thee are hundreds of codes that begin "ASME XXX". Don't be lazy - be precise, you're an engineer.
Hi JStephen & LittleInch,
Thanks a lot for your information. It really helps me a lot in this case. I guess i got into the right place, thank you. Yeap, my mistake for not stating the correct code for ASME, should be really careful next time.
