Tmoose
- Apr 12, 2003
- 5,628
A large experimental machine is being built. Finished Bearing bores are over 24 inch diameter and about 108 inch C-C.
We need to confirm bore-to-bore alignment and also position a 120 inch inside diameter stator relative to the bearing bores. Laser kits for stuff this big is a little rare.
What kind of tolerances are practical and reasonable using a "taut wire method ?
Thanks,
Dan Timberlake
Thanks,
Dan Timberlake
