TEM EVO Control System 1
Md. Mizanur Rahman
3
Can any one tell me why ZA Read Telegram Fault occur on MWM TEM Evo sysem? Is there any precaution of this fault?
Please Help me........
Hello Hoxton. How are you? Do you know anything about this.
1. Is it a data communication problem? or
2. Is it for hardware problem? or
3. Is it for software problem?
Please let me know. It will be very helpful for me......
I cannot find the document I need, but I think it is a communication fault.
The TEM, like many controllers can either run the genset itself, at a fixed power level, or take power commands from a higher-level controller via a Modbus link. If there is an error in the data exchange, then I think this is the fault.
There should be a number code for each fault, there will be a table of codes in the manual, which should help you track it down.
Hi Hoxton,
You are really very helpful Sir. Many many thanks for your replay......
