EngineerPhil
Petroleum
I am wondering if there is a temperature at which H2 embrittlement starts?
I have a vessel or test flat ened cylinder which I use to pressure test parts at ambient and at elevated temps. The material is phosphated AISI 4145 with a yield greater than 110k psi. There are no welds as the end caps are like flanges and screwed on with stub acme threads. i have some small port holes about 1/4" that are used to fill the vessel. The vol is 10 litres max and the design pressure is 14.5k psi.
I want to know if it would be safe to test at 320°C. I had designed the vessel for testing at a max of 200°C and 11.6k psi, and hadn't really considered H2 embrittlement. Do I need to worry about this now at 320°C.
I think know what H2 is but can't find anything that says if AISI 4145 is susceptible to it or not and if so what temps to whatch out for.
Anyone have any ideas?
Phil.
Phil.
