jmen68
- May 7, 2012
- 40
I need help with a temporary fix. I need to design a sliding bearing to shift a bridge a few inches (like 2in max). 5 girders max vertical reaction at each girder will be about 50 kips. My plan is to jack the bridge up using hydraulic rams, place a PTFE sheet sandwich between the bottom flange and bearing plate, then use some hydraulic rams to shift the bridge parallel to the bent. The PTFE sandwich design and considerations is where I am looking for some help... I plan to use some "off the shelf" PTFE sheets from Mcmaster, I don't think I should need and special reinforced sheets, unless told otherwise by you guys? Any input on thickness? My planned sizes of sheets will be 20" x 20" so 400 sq-in, bearing load will be 150 psi. Would you lubricate also, my reading tells me that it shouldn't be necessary. Thanks for any input.
