PostFrameSE
- Sep 5, 2007
- 174
I have a project where a customer reported that his attic temperature was 170 degrees on a 90 degree day. That seems a little warm to me. Obviously with temperatures like that, the building is only subjected to dead loads or wind loads. The trusses and purlins are designed for snow loads more than anything else. Will there be adverse effects on the lumber due to short term high-temperatures? I know that the NDS has reduction factors due to high temperatures, but my building will never be subjected to high loads at high temperature.
Also, what is an acceptable temperature differential between an attic space and outside air?
Thanks.
Thanks.
