Feb 7, 2024 #1 Waqas-999 Mechanical May 18, 2023 5 0 0 PK My question is there any upper temperature limit up to which ASME section viii division 1 can be applied. or there is no such limit
Feb 7, 2024 1 #2 SnTMan Mechanical Jan 22, 2005 6,780 0 36 US Waqas-999, no upper temp limit as such in Sec VIII, Div 1, but rather upper temperature limits for materials as shown in Sec II, Part D. Regards, Mike The problem with sloppy work is that the supply FAR EXCEEDS the demand Upvote 0 Downvote
Feb 7, 2024 #3 XL83NL Mechanical Mar 3, 2011 3,043 0 36 NL The highest you can (currently) go is 982 deg C or 1800 deg F. Huub - You never get what you expect, you only get what you inspect. Upvote 0 Downvote
Feb 24, 2024 Thread starter #4 Waqas-999 Mechanical May 18, 2023 5 0 0 PK @XL83NL which clause of the code says that. or if it is from some other literature kindly mention it as well. Thank you Upvote 0 Downvote
Feb 24, 2024 #5 XL83NL Mechanical Mar 3, 2011 3,043 0 36 NL It’s from ASME IID, where the tables list the max temperature for the material under consideration, per the applicable design Code (column wise). Look e.g. for UNS N06617. Huub - You never get what you expect, you only get what you inspect. Upvote 0 Downvote
