Tension-only bracing 1
jechols
109
Is it appropriate to use tension only members in K-bracing or V-bracing in an OCBF?
If one leg of the chevron does not act it seems to me that it is no longer a concentric system.
No,
do a free body diagram and you will figure out why.
csd
csd72
can you be more specific.Are u concern with the vertical component of the tension bracing at the mid of span of the beam ?
SHBH,
yes, it is the large vertical force in the centre of the beam, the brace no longer acts as a K-brace(where the 2 vertical components cancel each other out) and will be a very innefficient way of bracing.
csd
Thanks everyone for your comments!
